What 1 Will Be Better
Username: Shadylimitedx
Pgh, Pa Usa
Post Number: 407
1 15 re sx in a 3.944cuft ported box tuned to 28hz or 1 12 re sx in a 3.521cuft box or a 2.686cuft box tuned to 28hz both will b powered wit a ed nine 1 what 1 will b the best in loudness an best bass
Username: Nutty91rs
Bloomington, Indiana USA
Post Number: 181
... the 15, it has a huge cone area advantage. I don't understand why you're asking this its obvious the 15 will get louder and probably sound very similar in a vented enclosure to the 12 SQ wise.
Los Angeles, CA USA
Post Number: 584
you want loud bass or deep bass? why you set the frequencies so low?
Pgh, Pa Usa
Post Number: 408
ill go wit the 15 then but i like low bass an also like my bass heard me while it still stays loud in the car
Username: Nutty91rs
Post Number: 185
The 15's probably the sub for you, it's going to be very similar to the 12 with more output and it seems that's what you're after. Good luck with the setup.
Username: Frkkevin
Fort Worth, Texas US
What type of music do you listen to? The 12s would be better if your more into rock but if you listen to rap or other types of music with deep/varied bass the 15s are the way to go. More air flow = more bass. The 12s frequency response would be a bit quicker than the 15s though.
Pgh, Pa Usa
Post Number: 409
ya rap so the 15 it is
