Need help on sub size!!!!!
Username: Mixmastaspig
Okanagan, B.C Canada
Post Number: 300
K I need either 1 15" dual 2 ohm sub that can handle 2000 rms or 2 12" subs that can handle 1000 rms x 2 @ 1 ohm.
Specs on amp:
Cont. Power 4 Ohm 2 x 500 Watts
Cont. Power 2 Ohm 2 x 800 Watts
Cont. Power 1 ohm 2 x 1000 Watts
Cont. Power Bridged 4 Ohm 1 x 1600
WattsCont. Power Bridged 2 ohm 1 x 1950 Watts
and the amp retails for around $2,400 Canadian so its a top end amp!
I want to compete in DB drag so I would like somthing that will help me the most! I plan to build box to specs, and also I have a fairly big trunk and am willing to use it all for the stereo! up to $1000 on sub(s)...less is prefered!
thanks alot
Username: Nickboarder27
Inland EmpireUSA
You can get a JL 13W7 for around 750 and a JL 1000/1 for about the same. So the pair will run you 3000 for amps and drivers. 2000W rms no heat problems also very efficent.
Username: Subman15
Lwarenceburg, Kentucky United states
Post Number: 44
here are some good options:
digatal designs 9500 15" 800$
re audio mt 18" 500$
kicker sx 18" 700$ off ebay
orion h2 15" 400$ off ebay
these subs would get really loud
Post Number: 301
K any more brands I can compare !
thanks for the ones allready
Post Number: 302
Oh an I allready have an amp....and im sure its better than the JL 1000/1 as the amp I have is $2,400 and is Helix.
so what would hit higher SPL 15, or 12?
Say the sub were the same model of subs same power in the box built to specs?
thanks
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1362
hey alex what ebay are u lookin at, H2 are like 200-250 and Solo's are like 400.lol. Anything from DD 9500. Or the world record holder 2 12 Pioneer Premiers
Post Number: 303
How are the step down from the RECORD holder subs from pioneer? the ts-w3002spl? 3000 watts max
Post Number: 1380
loud as hell, great spl sub, I would go with that, DD 9500's, or Solo X, also i misposted, he had 13 of those subs
Post Number: 304
So the TS-W3002spl is a good go? I want to beat Kicker L7 subs!
Post Number: 305
I meant the SUBS BELOW the record holders...I dont have enough cash to buy 2 amps to power those! so NOT the 5000 MAX watts......the 3000MAX!
thanks!
Post Number: 1406
what size are the l7's
Post Number: 308
2 12" kicker L7's or a 15" either or. I figure since the Pioneer can handle for watts both rms and max MORE than the Kickers and that it is an SPL sub that I will HOPEFULLY beat the L7's. My brothers friend will be hooking up one 15" Kicker L7 to a Kx1200.1. And My amp will be 2000rms so I want to torque him!
