New member Username: DjbeanpolePost Number: 4 Registered: Nov-05 | I've had my "system" in my car for a few months now. I'm starting to look at other stuff and have been reading and researching everything I can but I still have some questions about things I don't get that I hope you fellas could explain. What is the difference between single and dual voice coil? Besides 1 v. 2, what is the benefit of dual if any? My amplifier right now is an Alpine MRD-M500. I have never once touched the controls after my friend installed it and I actually have no idea what they do. There are a ton of numbers that I can cycle through to change different things. Would changing any of them be beneficial to better sound? They are listed as follows: INPUT MODE LPF SUBSONIC PARAMETRIC EQ BASS COMP. TIME CORR. PHASE AMP SET SAFE MODE MEMORY SELECT The amplifier specifications list this: 900W MAX Power, 500W x 1 (2ohm 14.4V) Does this correlate with anything at all to my current subwoofer (Infinity Kappa Perfect 10.1D) numbers?: Power Handling, Peak: 1400W, Power Handling, RMS: 350W I was planning on upgrading (eventually) to 2 12s, and a guy I talked to at a shop here in Indy recommended Memphis Audio. Would my current amplifier be able to handle this? What does it mean for an amplifier to be mono versus channeled? Thats all I can think of right now. I'm sorry if they seem like really dumb questions to most of you I am just very curious about what all of the technical information means. Thank you ahead of time for taking the patience to read this post. Dave |
Silver Member Username: TheelfkeeperStockbridge, GA USA Post Number: 502 Registered: Feb-05 | hey, i just replied to your other post. but as far as this one goes, all your questions can be answered at www.bcae1.com site has just about anything you'd need to know. |
