Which is loudest out of the two??
Tim Is Here
Which would get louder:
a) 1 12" sub (300wrms) powered with 241wrms @ 4 ohms
b) 2 10" subs (250wrms each) powered with 500wrms @ 2 ohms. (each sub will see the full 250)
Thanks guys!!
Username: Quickshot
Charlotte, North Carolina U.S.
Post Number: 397
generally the 2 10"s(if the same model) but you cant use wattage as an estimate of whats louder it depends on efficiency and the overall goal of that sub whether its SQ or SPL
Los Angeles, CA USA
Post Number: 402
gotta be more specific tim.
Tim Is Here
the subs are both infinity's.
A) 12" - 1230 (300wrms)
B) 10" - 1030 (250wrms)
I kno that if I get one 12, I'll be underpowering it. My amp does around 241wrms @ 4ohms and 500 @ 2ohms. I think the 2 10's will be a better match. How loud will these get compared to one 12? They will each get .75cuft (what infinity recommends). I'm more into SPL than SQ......2 10's better?
Tim Is Here
how loud will the 2 10's be compared to 1 12?
Username: Six
Flint, MI U.S.A.
Post Number: 227
If you want the 12's i have 4 of the infinity 1230w's for sale. Just a thought.
Username: Taylor17
Kopperl, Texas
Post Number: 3260
The 2 10's will be roughly twice as loud.
Do to the extra amount of watts/surface area.
Tim Is Here
excellent.........I guess the only thing is that it won't hit as deep
