Anyone have optimum ported box specs for 2 type R 12s.
Username: Hootz
Saskatoon, Saskatchewan Canada
Post Number: 18
Anyone know of tested box specs for 2 type R 12s that sounds good?
Username: Rovin
Trinidad & T...
Post Number: 2366
i ordered 2 for myself & usually u get a spec sheet when u buy a new sub .....
Los Angeles, CA USA
Post Number: 372
optimum vented box
external dimensions ------------- 18" x 13.5" x 16.5
gross internal volume ----------- 1.7 cu ft
vented area (dimensions) ------ 12" x 1.25"
vent length -------------------------- 22.75"
vent displacement ---------------- .305 cu ft
net internal volume (Vb) -------- 1.3 cu ft
F3,ripple,Fb ----------------------- 33hz, 2.5db, 36hz
based upon 3/4 baffle thickness, with opening cut approximately to gasket inner diameter.
Username: Hootz
Post Number: 24
So with 2 subs, are you best to just double the width, then split it into separate chambers? Or keep it open?
Username: Hootz
Post Number: 25
They'll be running off one amp, so they should be getting equal wattage and everything. I would split the two off unless there's something to gain by keeping it open....
Los Angeles, CA USA
Post Number: 374
those are the specs for one sub so if you have two then build a box with separate chambers with each chamber having those specs.
