Help with amp, 1 or 2 channel?
Username: Iilovepiink
FL
im not sure if i want one or two 12' speakers. is there a way to buy an amp that can be used for both one and two speakers if i decide to switch?
Username: Rovin
Trinidad & T...
Post Number: 2329
Hey ! - u registered , u r probably the olny female currently on this car audio section which is quite a refreshing change .
Have u decided to increase your budget ?
Yes there r ways of doing what u r asking - eg buy a 500wrms 4ohms DVC sub & run it using a 1000wrms @ 1ohms amp that also does 500wrms @ 2ohms (cause a 4ohms dvc sub when connected = a 2ohms load) .
So now when u decide to buy a 2nd exact sub then when both is connected together = 1000wrms @ 1ohm .
Have u read http://www.crutchfieldadvisor.com/S-ymhkeYjMfQy/learningcenter/car/
www.bcae1.com , www.the12volt.com
all good read for the beginner so when the guys talk to u , u will @ least have an idea .......
Username: Rovin
Trinidad & T...
Post Number: 2334
Oh - & btw , i noticed that Chad Lee has the same car as u so he could give u a few pointers .....
FL
awesome, thanks for the advice =)
Username: Crazydude
Post Number: 29
first decide which subs you want and also whether you want one or two. then decide on an amp to power those subs. if you want to have some trunk space i would recommend one sub. one sub can sound just as loud and nice as two subs if placed in a nice enclosure and has decent power going to them.
Username: Rovin
Trinidad & T...
Post Number: 2338
Chad Lee has 2 Alpine 12" 1242D type Rs in his car btw - which i helped him choose & he's happy with ....
Los Angeles, CA USA
Post Number: 352
you didn't help me choose that, rovin did. don't try to take credit for what rovin did.lol.
Username: James1115
Wilton, Ct
Post Number: 4198
lol
Username: Rovin
Trinidad & T...
Post Number: 2344
oh no ! - Rovin is gonna @#$%! me up for claiming credit for his work ..........
