My system as loud?
Username: Yamahabanshee1
Paulding, Ohio USA
Post Number: 239
Well guys i know this isnt the best set up! But which one of these will be loudest and what would be second place?
#1- 2 12" RF P2's with a 700watt alpine amp 8guage amp kit, Pioneer HIghs and hu. Ported to 37hz box with seats folded down in a Grand Am
#2- The Visonik V123BP with a Audiobahn A6004T amp 4gauge amp kit, Pioneer Highs and Hu In a ext cab s10
#3- 2 12" Fusion PowerPlants in a Ported 38hz box, Audiobahn A8002T amp with 4gauge amp kit, Pioneer Hi's and HU in a ext cab s10.
Put umm in order from loudest to weakest! Thanks guys!
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1240
3 and 2 would sound louder since the subs are in the cab, but 1 would acutally be louder than 2
Paulding, Ohio USA
Post Number: 241
Thanks man!
Paulding, Ohio USA
Post Number: 242
any1 else
Los Angeles, CA USA
Post Number: 361
i would say 1-3-2. you can't underestimate those RF P2's. and with the backseat down, it can get loud in the car.
Post Number: 1281
maybe with the back seat down, but the fusions are more effecient then the P2's and u are feeding the p2's 150 more watts than they can handle ( i think they are 200 rms)
Los Angeles, CA USA
Post Number: 364
who am i to argue with you chauncey. nice to see you back. where have you been.lol.
Username: Rovin
Trinidad & T...
Post Number: 2358
Are those your only choices ???
i agree with 312 since those FPP subs are 400wrms each , not sure about Visonik sub but its def the lowest ranking of the 3 .......
Post Number: 1284
im no glasswolf or anything so u can argue all u want, but u wont win.lol. anyway my evil twin brother had locked me in my roomand i couldnt get out.( I really do have a twin brother btw)
Los Angeles, CA USA
Post Number: 366
hey smitty if those three setups are yours and your two friends then get it metered. let us know who wins.
Post Number: 1288
hey chad did u ever cover the holes where your speakers used to be
Paulding, Ohio USA
Post Number: 243
ight i will guys!
Los Angeles, CA USA
Post Number: 369
no. why would i? thats where the bass enters the cabin.
btw you think this will work out okay?
take out the 6.5 components from the door and replace it with the 6x9s(need to customize my door to do that)
add a tweeter to the top portion of my doors on both sides.
i already have two tweeters mounted in the dash where the stock ones used to be.
put the 6.5 spkr on the side bottom by the feet.
6x9s and a pair of tweeters would connect to the rear channel of my amp without the hpf on.
components hooked up to the front channels on my amp with the hpf on.
you think thats too much speakers in the front?
Paulding, Ohio USA
Post Number: 245
O ya the visoniks are 600max each watts!
Post Number: 1293
if u dont mind the holes, i was thinkin maybe you could put a grill or somethin over the hole. Also i wouldnt add more speakers without more bass(overkill). And Smitty never go by max watts
Los Angeles, CA USA
Post Number: 370
my car has the stock grills that bolt on to the rear deck so you wouldn't even notice it. you can't tell if there is a hole there or not.
Paulding, Ohio USA
Post Number: 246
ok then 300watts rms each sub!
Post Number: 1294
great!!!, i was just wondering where u riding around in your nice car with noticable big holes in it
