NOT LOUD NE MORE!!!:S
Username: Pikesh
Toronto, ONtario Canada
Post Number: 247
Well guys... i dont think my system is loud ne more.. everything is same... it was louder becuz it shaked my trunk pretty bad b4 not ne more... only diffrence or change there is now that i change my speaker wire.. i was running a nice one but then i lost that so i am running subs from this thin sh!T cheap speaker wire.. could that be a reason?
Username: Young_james
Post Number: 132
could be quite possible. It seems like it's a good chance since it was perfect before you changed the wire and then when u changed it, it sucked. You didn't hit the RCA's or n e thing loose in the process did ya? Eliminate the wiring, and if that doesn't do anything, just buy the same speaker wire you had before.
Username: Pikesh
Post Number: 249
nahh man.. i just took out subs once.. and lost the wire so i had sh!t one on my hand at that time...ill try that.. also...does ne one who where to place sub in trunk... to get MAX bass
Post Number: 133
generally speaking, the best spot is to have it in the rear of the trunk facing the back of the car. However, it works different in every car. I suggest that you full around with it yourself and see what you like best.
