Do most songs not have good SQ or is it my setup?
Username: Iufan4lifeul
Post Number: 727
I honestly don't think the bass is that clear in some songs that I play. RE12's in a sealed box SHOULD have pretty good SQ, and they do, but only on certain songs. Country for example, the bass guitar sounds like a guy is playing one in my car and the bass drum is crisp, clean, and accurate. A lot of other songs though really aren't that good including all Metallica, Crossfade, Seether, etc. They seem to just be a ton of bass thrown together. I have the RE12's in a sealed box with 1.25 cubic feet per chamber. I might try to go to a 5 cubic foot ported tuned to 35Hz for some more output and SQ. What do you all think?
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 146
your gunna lose some sq just by going from sealed to ported
Username: Solacedagony
New Jersey US
Post Number: 595
One thing I would double check is to see what your LPF and HPF are set at, more specifically the LPF.
Post Number: 731
So is the muddy bass in a lot of songs normal? Not a whole lot of rock songs are crystal clear bass.
Username: Iwrk4satan
Post Number: 28
I think it does really depend a lot on the individual recording. I know that a lot of the underground heavy metal I listen to, bands that don't have a ton of money and aren't too popular, just have crappy recordings. There are some specific recordings that just sound better in SQ to me than others. Check out Rage Against the Machine, self-titled album, Incubus - Morning View, as two of the best on pure SQ. Metallica - Kill em all is imo a great recording, as are most of their other albums (Justice for all sounds kinda muddy sometimes). But I have found that depending on the band I sometimes have to tinker the EQ to get the sound that I want.
Los Angeles, CA USA
Post Number: 275
kenny g really sounds good in a car with system. the bass sounds good and the highs are awesome.
Post Number: 732
thanks for your all's input. I just stuck some of the best SQ songs I could think of in my car and they sound absolutely AMAZING so it isn't the system. My head is pounding because I turned up the bass pretty loud so that it was pounding my brain. lol
I guess that's the down fall of good sound systems. you can hear the imperfections of some recordings. even most mp3's are pretty bad compared to the original recording on CD.
Username: Spyder
Eglin AFB, Florida USA
Post Number: 197
unless your smart and rip them off a dvd audio disk and compress them at 320k they won't sound as good as a properly mixed cd if you have the system.
Username: Suleman36
Maryland U.S.A.
Post Number: 2563
Chris what is your LPF and HPF set to ?
Set your LPF to 80hz and your HPF to 80hz and see how that sounds and let me know.
Also turn off any extra bass boosts on your HU
