Amp for 4 Ohm subs
Username: Emceetricky
Post Number: 20
I have 2 12" Rockford P3's and they are at 4 ohms and 500 wrms each. Does anyone know of a good amp that is stable at 4 ohms but still gives good amount of power considering my 1000 wrms total. I also dont really want to pay more than $300. Thanks.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 1244
u can wire them to be a 1 ohm load
Username: Robert_d
MIA, FL USA
Post Number: 360
kx1200.1
Post Number: 21
see thats what i was wondering. So i can wire the subs to be a 1 ohm load? Is it hard to do? Lets say i got like an MTX Thunder 81000D amp that has 1000wrms @ 1 ohms, can i use that amp even though my subs are 4 ohm subs? That is basically what i am asking because amps that have 1000 watts at 4 ohms are REALLY expensive and i dont wanna pay more than $300.
Post Number: 1245
sure can
http://www.the12volt.com/caraudio/woofer_configurations.asp
