NOT LOUD NO MORE...
Username: Pikesh
Toronto, ONtario Canada
Post Number: 248
Well guys... i dont think my system is loud ne more.. everything is same... it was louder becuz it shaked my trunk pretty bad b4 not ne more... only diffrence or change there is now that i change my speaker wire.. i was running a nice one but then i lost that so i am running subs from this thin sh!T cheap speaker wire.. could that be a reason?
Username: Bga44
Post Number: 26
u need good wire. thats like benching 500lbs with a paper bar. not a good connection. u should always get a new receiver to get the best signal, then good amps to increase power of signal, the good speakers and subs to play the signal. this signal is connected by wires all the way from the beginning
Username: Invain
Michigan United States
Post Number: 4054
"u need good wire. thats like benching 500lbs with a paper bar. not a good connection. u should always get a new receiver to get the best signal, then good amps to increase power of signal, the good speakers and subs to play the signal. this signal is connected by wires all the way from the beginning"
I'm getting tired of fixing your posts. It's appearant your have no clue what your talking about, and your advice is flawed.
Wire is wire, it doesn't matter what you use, and the gauge doesn't matter nearly as much as you'd think. Power and ground wire certainly need to be a certain size relative to the amperage being pulled, but the current passing through the speaker wire is ac, and the size of the wire doesn't make near the difference. You'll be fine with anything 20 gauge and lower.
Username: Bga44
Post Number: 38
thats what im saying, u need good wire for the battery and amp. but old cheap wires will not be sufficient to carry a quality signal
Username: Invain
Post Number: 4058
He wasn't asking about his power supply wires. He was asking specifically about speaker wire. The quality of speaker wire will not effect the performance. Like I said before, wire is wire, there is no real big difference between a 10 dollar spool of 12 gauge and a 80 dollar spool of 12 gauge.
Username: Bga44
Post Number: 42
there is such thing as bad speaker wire. not any wire will work
Username: Invain
Post Number: 4061
Wire will in no way effect the sound quality, and almost all wire is made of the same basic elements. As long as the gauge's are the same, there is little to no difference, besides the large corporate company trying to r@pe you by charging 50 bucks for "high end" speaker wire.
Username: Bga44
Post Number: 51
he said he had nice wire, but now has thin wire, obviously gauge change. gauge change will effect it. speaker wire wouldnt effect the sound that much i agree wit u, but he said he went from nice to thin
Username: Iufan4lifeul
Post Number: 745
how "thin" is thin? That might be your problem. Sounds a lot more like you don't have the subs wired down to a low ohm like the must have been before. Check all of your wiring and make sure it is all wired correctly.
Username: Pikesh
Post Number: 252
well i had it parallel wired putting 2 ohms of load..( mono amp and 2 subs) the subs are SVC and 4ohms so yeah.. the wire is kinda sh!T becuz everytime i try to peel it off, the outside of wire stretches... its a bad wire...
Username: Rob_preg
Royal oak, Michigan United states
Post Number: 174
hey pikeshp, are you in pi kappa alpha by any chance
Username: Redskin
LondonEngland
Post Number: 214
"As long as the gauge's are the same, there is little to no difference, besides the large corporate company trying to r@pe you by charging 50 bucks for "high end" speaker wire."
$50 dollars for high end? check this out.....
http://www.russandrews.com/product.asp?lookup=1&region=UK&currency=GBP&pf_id=336 1&customer_id=PAA1195119905284XUECVVVZIVULORVU
Where are the people who buy this when I'm selling stuff????
Username: Pikesh
Post Number: 255
infinity Kappa subs??? two4fifteen?
Username: Invain
Post Number: 4071
Kimber is an exception...
