10w7's or elsipse 10inch ti's which and why?
Teeg
im buying 2 tens from ebay off indoaudio and i was wondering which would u guys go with? the w7's or ti's(either would be powered by a 1000/1 i was thinking..?)
opions and why would be great thx
Username: Subman15
Lwarenceburg, Kentucky United states
Post Number: 22
the eclipses can handle more power, and i would go for them
Username: Subman15
Post Number: 23
the eclipses look cool too
Username: Lil_jon
Post Number: 204
does the ti sound better then the w7?
Username: Spyder
Eglin AFB, Florida USA
Post Number: 195
the Titaniums in my experience don't perfom as good as the W7's. but the titaniums are generally cheaper. they both will sound good but the W7 will be louder and sound better if the box is built right. but go with what you can spend man!
Username: Carguy
Post Number: 5026
Listen to W7 in HO box first then decide.
Teeg
alright sounds like the w7 in a HO box takes it for all around performance which was exacly the answer i was looking for , thx for all your help guys
