Problem Installing CD Deck
Closed: New threads not accepted on this page
  Thread Last Poster Posts Last Post
Archive through May 08, 2005Jexxen Trivic99
d0ct0rg0d
ive looked at tons of ford schematics and none fit what ive got. i hooked up the acc, the battery, and the ground up. then i took 2 speaker wires (of the same speaker) output from the headunit and tried tons of combinations of the wires left from the explorer with not a single noise made. so im in the dark now. the only other thing i can think of is to check the crappy factory amp thats in the back right panel of the suv and make sure thats geting power and where its sending its signals to. o well i guess
Username: Illuminator
Post Number: 153
You didn't tell me you had a factory amp! I bet it needs a signal from the headunit to turn it on, and the wire to turn it on isn't hooked up! Personally, I would just bypass the amp...
d0ct0rg0d
yea, im an idiot i forgot all about it at first. i have yet to try that out, but thats what i think ima do too. just rip the POS right out.
Hey guys can anyone find me a wiring details or Harness on a Ford Laser lxi 95/96 model please, thanks
I have a 1991 ford exploder and I am trying to get out the factory radio and I got the tools to do it but it seems to be stuck. Does any one have any suggestions
BigD2005
HELP!!!! I have a 2000 mercury sable ls and i'm trying to install a panasonic cd player in it. i have tried looking for a wiring harness to put in it but no luck. does anyone have a diagram of the wiring going to the factory radio? i'm gonna try to splice the power wires from the factory harness onto the one i have on the cd player. please e-mail me at big.drizzt@gmail.com if you have any info. thanks
Username: Guitarjoe
I'm lookin for the color codes for my '92 ranger the harness was cut off when I bought it.I cant find the codes for it anywhere.
99 ford taurus, radio already installed but cannot figure out where to hook the new rear defroster switch on the aftermarket harness, any one had this problem, any help would be appreciated
Username: Camaro11388
Please help me. I've got a 2000 jetta. Trying to replace 2nd aftermarket stereo. Originally I had a jensen head unit and I took it out to put in a JVC unit. I connected the wires from the jvc with the same color wires that went into the jensen. I think they are all correct. While doing so, the red (ignition?) wire touched the yellow (battery?) wire and I blew the fuse. I changed the fuse and now all that happens is I can eject a cd or load a cd into the head unit but it soon shuts off. It will display the clock but that also soon goes away, even without the key in it. I am pretty sure the radio works fine becuase when I touch the red wire from the head unit to the yellow battery wire it powers up fine with no key even in the ignition. Did I blow something out? Please help me I really dont know what to do from here.
Delvon
i have a 96 ford contour and the previous owner spliced the wires. i just bought a new cd player and i need the wiring codes for it.
k,o;jmi; jn
1990 mercury sable gs color codes please
Post Number: 499
You don't need them. Buy an aftermarket wiring harness.
Post Number: 500
DO NOT CLIP YOUR FACTORY WIRING HARNESS! BUY AN AFTERMARKET WIRING HARNESS!
Username: Nissan_drifter
I need to know if there is any way to hook a Sony Xplod head unit to a 92 Ranger without a harness adapter. I can splice wires relativly well but i need the color matchups. Much Thanx
Post Number: 503
You can, but think about it. If you ever sell the car and have to put the original unit back in or want to put in a nicer unit, you will spend a great deal less work by buying the harness. Don't be cheap either, it won't be more than twelve dollars.
Why waste the effort with clipping the harness?
Necesito la conexion de los pins para los parlantes de una Sony Cdx- F5700 por favor ayudenme ya que la ficha no es la original y creo que le faltan cables. POr eso necesito saber cuales cables van con los pins para los parlantes. Gracias.
I have a 2000 civic and I am installing an aftermarket head unit. I hooked it up right, because it was working fine. Then I put everything back in the dash. I turned on my car and it did not even turn on. can somebody help?
Post Number: 514
Check the fuses, man, check the fuses.
and if there is nothing wrong with the fuses?
Post Number: 521
Then the wire got fried.
eeeron
anyone know how to take out the stock radio on a 2004 ford explorer? i want to install an aftermarket stereo but don't know how to uninstall the stock deck. thanks for any help.
96 probe SE
got the speakers connected, but can't find power and ground (those are the only other two that will hook up to my new stereo it apears, theres others, but i dont' think they're used)
the harness is mounted and 2 feet in, no way to get to it, so i just need to know which of the following is the ground and battery (on the wires from the stock head unit, top to bottem)
blue w/ red stripe
green w/ red stripe
blue w/ white stripe
orange
space
thick black w/ gray stripe
space
red w/ black or green, can't tell
car trouble
hey Glasswolf,
What is the color wiring diagram for a 1999 ford taurus? Please send your answer to andru_d23@hotmail.com
thanks
Username: Steeler
Ireland
I have a 1989 suzuki swift with no radio I have a recent bluapunkt radio with modern iso connections and I have the colour codes for them but the original wire inside the dash I dont have a clue about I am assuming I can cut the old wires and join them to the corresponding new wire but I dont know what the old colours represent. PLEASE can any one help me......THANKS
Post Number: 665
1989 Suzuki Swift? And it's still running?! Crazy!
94 honda accord. ripped out the old without thinking. need to match up with a jvc cd/mp3 player. any help for me, please e mail.
grayson
i need to know which color wires go with the wires coming from the stereo
www.graysonschmidt@hotmail.com
grayson
ok. i got the wiring figured out, but now when i turn ther radio up really loud it shuts off. and it seems to be sucking all the life out of my battery.any suggestions?
Username: Dominirica012
Charlotte, North Carolina US
Post Number: 105
check the cd players ground because i hadnt and my alpine used to shut down on higher volumes too
grayson
ok but how do i check the ground. right now i have the black from the stereo connected to the black from the car. i dont know where the black from the car goes to. would it be better to ground it where i can see where it is? am i at risk of blowing fuses by touching different metal parts on my car?
GRAYSON
I THINK I MAY HAVE THE YELLOW AND THE RED IN THE WRONG PLACES. ANYONE KNOW THE CORRECT WIRES TO CONNECT THEM TO?
I have a 93 ford ranger XLT and the original owner really f-ed things up. I have a random black/white cable and random orange/red cable and weird stuff like that...any ideas??? Im tryin to install a kenwood kdc-mp922 and i have ground and two powers right but i cant get it to work correctly
Grayson
ok here is the correct wiring for a 1994 <a href="http://www.serverlogic3.com/lm/rtl3.asp?si=24&k=honda%20accord">honda accord</a>.
all the speakers are simple enough but i had a lot of trouble with these 2
from the car: from the radio:
white w/red stripe----------------red
white w/yellow stripe---------------yellow
if your car has 2 white w/yellow stripes, only use one of them. the other is useless and will only drain power from the battery.
if your car does not have a power antenna, you will not use the black and red wire(from the car) or the blue wire(from the radio).
much luck
Username: Jbmunee
Walled Lake, Mi
I recently bought an 95 Ford Taurus with no Radio in it and nothing but wires hanging. Is there a way for me to fix this situation. I bought a Durabrand CD player and tried to hot wire directly to the wires hanging but it wouldn't turn on. Your help would be appreciated
I am installing a cd deck into a 91 mercury sable and the deck just doesnt seem to turn on completely. It accepts CD's and ejects them, the clock comes on briefly when display button is pushed, and the display lights up temporarliy but then the display cuts out and nothing happens. if anyone has the color code for the Sable i'd appreciate it!
ggdgd
i already cut the wires from the stock wire harness and if i could figure out to put them back that would be good too!
i've just hooked up a new cd player to my 96 ford contour sport. I have tripled checked every wire and there is still no sound through the speakers. please tell how to fix this.
chuck d.
yo, got a 99 ford taurus, got a JVC disc changer, disc changer has the red (power) yellow (memory) black (ground) but there is already a harness for a factory cd changer in trunk, i clipped the harness and am left with 3 wires () yellow w/ red stripe () black with pink stripe () blue. bought the antenna adapters. am i able to use these wires? use antenna extensions and wire into deck? i would appreciate any help or what the three wires in the factory harness are, thx
JVC KD-S590 car stereo.
Dose anyone have the code to change the radio USA to Europe (like 106.05 to 106.5). i did it before but lost the info, and I just had to replace the car battery. Lost all saved info on it.
i need some help!
i own a 1991 ford explorer eddie bauer edition and i have no clue how to take off the dash on it. if someone could help me out, it is much appreciated. thanks
mccartl@cwu.edu
well, you should go to www.installer-data.com and type in your model and make and you should defintely get something I have a Ford explorere ford 4dr and I was wondering did you have to by the taurus kit because of the facory amp and if so did you have to pull the panels of the door.
I have a 1996 ford contour I just purchased it has no radio and the harness has been cut out have looked at alot of ford radio color codes and haven't found the one that macthes what I have in my car. can anyone help.
GodCandy
I dont know that anyone actually responds to this anymore but I have a 1995 mustang. I just got a JVC head and it will power on and sound will come out (varified by hooking a speaker directly to the head) but the head does not appear to be sending sound through the OEM wiring harness. I do have the Ford adapters and everything appears to be correct. I have tried everything but it appears that this head just will not send sound through the oem wires for some reason. Has anyone else had this issus?
Username: Kamran654
Scottsdale, Az Usa
I have a 2002 Ford Windstar Minivan LX, my car comes with a cassette player and I just purchased the combo (cassette/cd) player over the internet. does anyone know how to take out the cassette player and put in this new combo cd/cassette player.
Post Number: 917
You're going to need the removal tools made especially for Ford. Or you can shove two flathead screwdrivers in on either side of the old unit and push outwards while pulling the unit out at the same time.
There is also the option of finding some other tools that will fit in the holes to remove the unit.
Mike_2552
Hey, i've been looking all over the web for the wiring codes for a 1995 Suzuki Swift so i can hook up my deck, i was wondering if anyone could get me the wiring codes for my car.
mikeymackinon
use http://www.the12volt.com/
instead of http://www.installdr.com/
Mike MacKinnon
Username: Tcrulz_2006
Cody, Wyoming United States
I need help installing a Pioneer Deck in a 92 GMC Suburban. Email me at tcrulz72@gmail.com.
I really need HELP!
Hey there, i need help taking out the whole Heat/AC/HU on a 96 ford taurus. everything is still oem and im trying to figure out how to get some subs without having to get a new deck.
if anyone could help me on this - kiko130@hotmail.com
thanks
Post Number: 1011
You need a new deck. Using an output converter will decrease the sound quality considerably.
i am trying to install a JVC CD player in my 1992 Honda Accord but my wiring harness is gone i need the wiring code can anyone please help me?
Post Number: 1034
Yep, check the links already posted in this thread.
i'm trying to hook up an aftermarket cd player in my Audi 80 Quatro. I looked everywhere for a harness for one but couldn't find one. can you tell me what wire is what? the year of my car is a 1988.
Post Number: 1164
You checked the links already posted in this thread?
Username: Cbad
Alamogordo, Nm United states
does anyone have the wiring diagram for a 1999 ford contour would realy appreciate the help.
I've hooked up a new radio in my 93 explorer and when I hook up the first speaker there is no sound, but when I test it on a home speaker it has sound. Do I need all (4) speaker hooked up to work?
Username: Mrk
I need help I've hook up a new radio in my 93 explorer and when I hook up the first speaker there is no sound, but if i hook up a home speaker it seems fine. Am I doing something wrong?
Thanks,
MR.K
whats his name
I havve a 57 chevy sitting on a 74 gmc frame. don't know where or what to do with yellow wire (constant power) does it go to the battery? If it does do I need a inline fuse? what size fuse? Oh , it's a pioneer DEH-1600 cd player/ tuner. Thanks for your help.
need help installed a sony cdx-f5710 in my 95 jetta removed factory radio soldered new wire harness to wireharness for sony deck pluged it in worked for a while put it in dash then never worked again.... my car doesnt even have the alarm when the door is open anymore what do i do idk what to do.. did i blow a fuse ... need help badlyim totaly lost.....
MikeDoh
I have a JVC kd-s590 and some of the wires are missing from the harness coming fromn the unit itself. Does anyone have a diagram on wheere they go? Its missing the greound and the switched power. Thanks
-Mike
Username: Gpz1100
Post Number: 51
Mikedoh,
Your manual should contain the wiring diagram for the harness. I've yet to see an owners manual that does not. I'd start by looking there.
Unbelievable
This could very well be the laziest most uneducated forum I have ever seen. It is as though no one reads any previous posts. You senior members must be going crazy here. You try to help but it does no good.
Post Number: 1312
Not necessarily lazy, but these threads come up first in google searches as far as help forums go, and because they are so general, everyone feels they can post their problem here. It's frustrating, definitely. But who knows, maybe something will change.
Albie
I have a 93 Explorer that came with the factory installed premium JBL speaker system. I recently switched out the tape deck for a JVC CD player, at the store I purchased it at and had it installed. My subwoofer blew about 2 months after I had it installed. Does changing just the deck change the output to the speakers?? I'm wondering because I'm not sure if there was something wrong with the installation, cd player, or if it was just coincidence?
I need the wire harness color codes for a '96 pontiac bonneville, im about to find out what the cd player is but i need those.
spent10minsfindinganswer
When you ask a new question, start a new thread!
It won't be so confusing and your question might actually get answered.
i need a wiring diagram for a 1999 ford ranger...my friend said he knew what he was doin but when i dont have the key turned i dont have any power to it and it has no memory i was just wondering if someone would help me
Username: Xblocklolx
Chicago, ILL USA
can some one help me?i get 95,Saturn,SL1.i try to install it.its work,but no sound,the cd just playing with out the music.and my car get few wiring are same...that is crazy,two yellow,two green,two brown.
i need help=[
or email me
xblocklolx@yahoo.com
Username: On2raleigh
I have a 97 Crown Vic. I just removed a Dual from my Dodge Durango.. Bought the Ford 97 Harness kit, did the harness switch... I put my new deck in and connected the the new Deck to the factory harness and nothing happened... Im wonderin if those Yellow and White plugs are supposed to be connected somewhere also, even though I dont see where they should go.. PLEASE HELP ASAP!!
ozzybuds
i'm having the same problem as glasswolf installing a sony cd deck.
can't get it to work at all from the iignition source. i wired it straight to the battery and it will now accept/eject cds but no display.
i'm stuck.
Ok guys, I'm stumped. I just installed a panasonic deck into a 89 nissan sentra. At some point it went back to the dealer and they messed with the pins in the harness so nothing matches anymore. I bought the correct book for my car that has all the wiring diagrams and going from that I've got +12v when the car is off going to ground, and +12v when the ignition is turned going to ground. When I power the deck on with the engine running, the display flashes on and off and on and off until i kill the engine, with the key turned but no ignition I get nothing at all. No lights, no action. Any ideas would be very apprciated. (voltages were checked with a voltmeter and all wires were stock, I havn't run a seperate ground or anything) I've rechecked the install for bad wires, but everything seems sound.
~confused mike
ff
Where can I get a factory harness for my 2001 jetta? Should the dealer have it?
Username: Sinecd
I just had circuit city install a new cd deck into my chevy cavalier and it worked fine for a while, then I just put in the rear speakers and it worked for about three weeks and now the cd deck wont play any sound. It turns on and seems like it is playing (the time dial for that song moves) but no sound. The deck is still under warrenty but I dont want to put a new one in if it is just going to do it again.
how do you uninstall a JVC KD-S5050
the manual is lost
i have a 1997 mercury sable and someone stole the stock radio out of it and just cut the wires. i bought the wiring harness and installation kit but i have a mess of wires.
Post Number: 1528
Please read the thread in its entirety.
I have a 93 ford taurus sedan and i just got a cd player and i dont want to spend money on getting it installed.. but i cant get the stock radio out of the car does anyone know how to get it out.
hey i have a 2000 ford explorer eddie bauer edition and i bought a radio for it a pioneer 600 series and i hooked it up and it worked but i didnt have a sleeve so i just sat it in the dash and it worked for one day and it fell in the back of the dash and it quit working i thought it might be the radio messed up so i took it to a place and they checked it and it worked so i hooked it up again but it still isnt working so what do you think is wrong with it cause i thought it might be a fuse but i checked all of them and they are not blown so i need help
MuFfDvR3
i have a 2003 ford taurus ses and i need a wiring diagram for the factory stereo. im wanting to hook up my amp and subs to the factory cause an aftermarket wont fit. is there anyone that can help me?
MuFfDvR3
MuFfDvR3
sorry for the double post
I got a 99 mustang, factory internal amps...I took out my old head unit, radio peice and cd peice, installed a pioneer one, just a basic one for now...It worked for about a month, one day drivin along my 4speakers just cut out, music wasnt even loud, all i had was sound from my tweeters, shortly after they went out too. i have no sound what so ever! When i installed the factory radio back in, (wire harnesses), all i get is sound from my tweeters... Any solutions? blown speakers?
I have a 2003 Honda Civic Si HB and have looked at every website i can find and noone has the wiring diagram for it. The wiring is as follows:
Top row
A - White w/red stripe
B - Red w/black stripe
C - Green w/black stripe
D - Green w/yellow stripe
E - Blue w/white stripe
F - Pink
G - None
H - None
I - Yellow w/red stripe
J - Yellow w/green stripe
Bottom row
K - Black
L - Red
M - Light Green
N - Gray w/red stripe
O - Blue w/black stripe
P - Blue w/green stripe
Q - None
R - None
S - None
T - None
I dont know what alot of these are.
i figure:
Black is Ground
Red is Ignition or Battery?
theres no yellow!!!!
someone help plz
greg kramer
in a 1989 buick lesabre i was installing a cd player when a copuple wires had sparked and now i get nothing out of the wires from the car and i only have 3 fuses in the fuse box which are all okay then two big black box fuses. i read the manual for the car and it had said this car had inline fuses where would i find such fuses in the car to get my stereo working again. or if any one has a wiring diagram for the stereo and the fuse box.
Help Please! We are trying to put a CD player in a 2001 Ford windstar. We bought a harness and got the wiring codes for the radio and matched accordingly, but still aren't even getting any power. Any help would be appreciated. thanks!
shaveen
hey.
i have a 1995 eagle talon tsi awd turbo and i just got a innovatek dvd player installed everything worked fine but when i moved my driver seat up the sound stopped working but it powers on and the dvd's work but theres no sound.
what could fix this problem. someone please help me. i checked the amp it stopped working too but the amp fuse and radio fuse are perfect.
Username: Dnl_creed
1994 ford thunderbird, 2 clips , 1 for speaks, and the other has 5 wires, anyone know which one is what ? odd color combo's
Username: Moondog1212
New York United States
Post Number: 20
you guys should just go spend $15.00 on a aftermarket wire harness saves a lot of time in the end
Post Number: 2001
They should, but they don't read...
Post Number: 23
lol. it makes things very simple, then you guys can match your wire colors together. lol
BillyMosh
they dont make one for a 96 sable, it stops at 95 then starts again years later
Hi there. I really need some help with my `92 Ford Explorer. I`m trying to reach the factory amp. where do I find it? And is it a lot of work getting to it? Should I instead spend 40$ buying an amplifier adapter? Any help would be appreciated.
Username: Azn_pnoyimport
Hi there. I really need some help with my `92 Ford Explorer. I`m trying to reach the factory amp. where do I find it?and what is the color code wiring amp.or e-mail me at azn_pnoyimport@hotmail.com so if anyone can help out here that would great so just sent me the answer on my e-mail add thank's...
HEY I JUST NEED SOME HELP WITH THE SIZE OF SPEAKERS IN MY 95 FORD TAURUS. THEY ARE STOCK NOW AND I WANT TO PUT SOME NICE ONES IN BUT CANT FIGURE OUT WHAT SIZE THEY ARE..HELP PLEASE.
I have a 1994 mitsubishi mirage. The stereo was ripped out before I got the car. I dont have a wiring harness and I am trying to install a cd player in the car, I got it to come on but then it goes off and on like it keeps loosing power what is wrong here?
Post Number: 2105
It sounds like some speaker wires are crossed...
D332
I recently bought a new DUAL CD deck for my 1997 Ford Explorer, I already had the Ford wire harness from my old cd player, but now when i hooked up my new one there is one orange, one orang with a white line, and one blue with a white line wires that the cd deck doesn't have to connect to. But Everything works perfect except there is no sound coming out of my speakers.
Does anybody know how I can fix this problem or what to do about it.
Thanks
Post Number: 2109
Ignore the orange wires, but the blue w/white stripe is the amp remote turn on. Your Explorer might have a factory amp that requires you to hook up the remote turn on in some way.
D332
There is a blue wire coming from the explorer harness, and one on the cd harness, should i put the blue w/white together with the 2 blues?
Post Number: 2110
Just connnect the blue w/white to the blue coming from the explorer harness.
D332
The blue w/white is coming from the ford harness along with a solid blue, there is just one solid blue coming from the cd player
Post Number: 2111
Ah, what model is the CD player?
D332
it is a DUAL XD7500
Username: Gpz1100
Post Number: 72
How do I unsubscribe from this thread??
iceberg747
I got a 92 caddy seville sts, does anyone have a clue how to install an after maket deck without re-wiring the entire car, please help, i hate radio,
I need a pin out for a F68F-19b132-ca ford radio. putting it in a older 70s ford. Where can i get a plug?(two plugs) Thank you.
ive got a 1989 mercury sable wagon with a premium sound system. i cannot find the factory amp to install the bypass myself, or find sites that tell you where it is. if anyone knows where it is email me at soadxtr573@hotmail.com, and title the subject as SABLE so i know it isnt spam. thanks.
HELP ME PLEASE! I am trying to hook up a Ford factory CD changer to a Ford factory stereo w/cassette and CD changer capability in a 1998 Ford Expedition. HOWEVER, I am having a little difficulty locating the wiring harness required in order to complete this project. I thought that the vehicle was equipped with the plug so that all I had to do was purchase the unit and install it. If someone knows where I can look for the plug (if already on my vehicle), will you please let me know? I've been working on this all weekend and haven't accomplished a thing!!
Thank you.
