Phoenix Gold Octane-R 15.0:1 Amp
Username: Spduff2
Louisville, KY
Just a couple questions about this amp. Why does it have two speaker outputs when it is supposed to be a mono amp?? Is there any specific reason for this. Do I just bridge it as I would a normal two channel?? Also, I can't seem to figure out the gain on this amp. Previous amps I have had have clearly stated which control is the gain, but on this it just has Input Sensitivity, Crossover Frequency, Twin-T Bass EQ (Bass Boost), and Subsonic Frequency. Thanks.
Username: Rovin
Trinidad & T...
Post Number: 2077
alot of mono amps have 2 outputs so that u can connect wires off 2 subs easily but it still gets the same mono power - its just to make wiring easier .
Input sensitivity IS THE GAIN .
