I wanna make my subs hit harder
Username: Bigherm78
Monmouth, Or Usa
Post Number: 13
i have 2 12 inch pionieer 600 watt subs and a 1000 watt phoenix digital amp that is 1000 watts and i cant get them to hit hard the subs sound like they are laging or cuting out
nick_sq
ported box? Cap? dynomat?
Username: Bigherm78
Monmouth, Or Usa
Post Number: 14
i got a sealed box
Username: Rovin
Trinidad & T...
Post Number: 1805
thats your answer right there . Sealed with those subs hold back the true potential of what they can do - port it to specs & your eyes/mouth will open ...Upload
Username: Bigherm78
Monmouth, Or Usa
Post Number: 15
they hit hard before but not as much since i rewired my deck from a direct power source to the normal one for the radio. they sound like there laging or sound like they cant handle the bass but i know they can
Username: Rovin
Trinidad & T...
Post Number: 1809
now u are describing what really happened - then put it back & see what happens
Username: Bigherm78
Monmouth, Or Usa
Post Number: 16
it killed my battery that way
Username: Rovin
Trinidad & T...
Post Number: 1810
the only way i can think that would happen is if u wired your amp rem wire directly too or 4got your deck on overnight ......
Username: Bigherm78
Monmouth, Or Usa
Post Number: 17
wut is the amp rem wire
Username: Iufan4lifeul
Post Number: 623
That is what happened right there matt! The amp remote wire lets the amplifier know when the HU is turned off so it can turn off. If you didn't have this, the thing would just keep running!
Username: Rovin
Trinidad & T...
Post Number: 1815
thats what i was getting @ -lol .
If your rem wire is connected to the + batt terminal then the amp does not turn off even if deck is turned off . The light on the amp will indicate that .
The rem wire is supposed to go on the deck's rem wire (usually its BLUE) so when the deck is switched off the amp automatically is shut off ...
Hope that was the problem & both of us was helpful .
Username: Bigherm78
Monmouth, Or Usa
Post Number: 18
thanks alot man i think it might have gottin undone
Username: Bigherm78
Monmouth, Or Usa
Post Number: 19
well i did that and they still are sound like they are lagging is there anything else that will make them hit harder
jcash
Yeah turn your gain and bass boost all the way up!!!
Username: Bigherm78
Monmouth, Or Usa
Post Number: 20
i think u said the same thing before and everyone was like dont do that so i wont trust you but the bass boost is all the way up and they still lag
WILLEATYOURSYSTEM
well for all of you retards, maybe he just has his subs wired wrong? pos to neg or neg to pos? if u do that backwards even on one side it wont beat hard at all...but u guys gotta get all technical...
Username: Killerzracing71
Fredericksbutg, Virginia United states
Post Number: 122
makes since alot of since
