Ohm question?
Username: Bretzy1990
Springfield, Il U.S.
can you run 2 woofers that are dual 2ohm off a mono amp. if so how many ohm's would that be
Username: Alias747
MN
Post Number: 825
Yes, in fact that is ideal in the case of most mono amps. It really depends how much power that amp puts out and how much your subs need. If you wire the subs in series/parallel you will end with a single 2-ohm load.
