Wiring"a"sub with a 2 chan amp
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 737
i have a 15 " type r... 4 ohm dvc
would a 2 channel amp that does 450 watts x 2 at 2 ohms be able to power it if i hooked each channel up to a coil?
yes it will work but you'll only be putting out 225w x per voice coil @ 4ohms. and it's usually not a good idea to hook up stereo channels to a sub.
the best way to go is get a mono amp rated at 2 ohms to whatever your sub can handle.
Username: Rovin
Trinidad & T...
Post Number: 2033
uh judging from
"a 2 channel amp that does 450 watts x 2 at 2 ohms "
i think he meant 450 in each channel but did not say it that was WRMS or MAX .
current model of 15" type R is 750 wrms so if his w are rms it can work but being carefull with the vol control .....
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1366
"and it's usually not a good idea to hook up stereo channels to a sub."
stereo to the sub is fine.
