Help!! 0.67 ohm issue
Username: Disturbedpriest
Post Number: 177
Okay if i wire up 3 subwoofers into a .67 ohm load is that shown on the amp as 1 ohm load or what??? my amp is only 1 ohm stable.. please help.. the subs are 4 ohm dvc.
Username: Six
Flint, MI U.S.A.
Post Number: 129
Don't Do that.
Username: Rovin
Trinidad & T...
Post Number: 1920
that will cause overheating & shutdown ,possibly some amp damage .
just use 2 of those subs instead or buy a 0.5 ohm stable amp like Mmats .
Post Number: 178
okay so is a 2.67 ohm load a 2 ohm load then?
Username: Geekbike
Post Number: 379
A 2.67 ohm load is a 2.67 ohm load. The power an amplifier will deliver is proportionate to the resistance in the circuit. For instance:
1250w at 2 ohms
936w at 2.67 ohms
625w at 4 ohms
Amplifiers are just rated at those levels for ease of comparison (might be an ISO standard).
Username: Rovin
Trinidad & T...
Post Number: 1955
if u wanna run 3 subs with 2.67 load best if u buy a Jl or Phoenix gold amp with puts out rated power between 1.5-4ohms(JL) & 1-4ohms (PG)......
Post Number: 179
ty for helping me okay i am glad i didnt hook my amp up at .67 ohms.. have a great day night year!! hehe
Username: Tdisanto
Post Number: 480
Whats the lowest impedance stable amp available, anyone know of the top of their head. I havent seen anything under 0.5 ohms. Let me know
Username: B101
Queen City, NC USA
Post Number: 68
.5ohms is almost a dead short! LOL
but theres a few that do it though.
that current draw will be huge!
Username: Rovin
Trinidad & T...
Post Number: 2006
only 1 brand new i can think of that won't kill u in price is MMATS
Username: Invain
Michigan United States
Post Number: 4013
I've heard of older amps running at .25 ohms. Might have been Orion, can't remember.
Username: Mikechec9
Http://www.cardomain.c...
Post Number: 1359
it depends on the amp. i know people running the ed 9.1 at .67 without fail or problems.
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 175
this is 0.25 ohms stable http://cgi.ebay.com/harrison-labs-drag-queen-10-000-watts-1-4-ohm-stable_W0QQite mZ5823901726QQcategoryZ4950QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
