Which is better?
Username: Hondarider
Glidden, Iowa U.S.
Post Number: 171
1.http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=2518
2.http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13889
Do either of them have a subsonic filter?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 882
there probably about the same but i would take the kicker, im not sure about the subsonic filter
Username: James1115
Wilton, Ct
Post Number: 4155
go with the kicker about having a sub sonic I am 99% sure it does go to kicker.com and check it out I would but they have the most annoying music ever I cant take that web site it gets me angry:-)
Los Angeles, CA USA
Post Number: 113
yeah what's up with that stupid music.
Post Number: 884
they are "livin loud"
Glidden, Iowa U.S.
Post Number: 172
would this be better than the kicker http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=592 I heard zapco was really good?
Username: Rovin
Trinidad & T...
Post Number: 1995
Supposed to be way higher ranking than K & RF
Zapco has been reputed as 1 of the best amps around
Isaac is experienced in that brand so he might see your thread & post ........
Glidden, Iowa U.S.
Post Number: 173
On that zapco amp it says it haas a remote bass gain is that basically a volume for the subs?
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 120
wow rockford and kicker have big price difference in watts.
