Radar Detector Help
Username: Joebruce
KY U.S.A.
Post Number: 257
Alright,i have a 01 s10 and my radar detector does not go off when i turn my truck off,anything that is plugged in the 12v sockets will not go off i have to turn it on/off everytime i get in and out of my truck.Is there any way i can wire it or something so it goes off when i turn off the ignition?Wut about the accessory wires on my wire harness to my cd player can i hook it up to that?
Zaghloul Saad Zaghloul
About the wire of the CD player, do not do that , because yopu will decrease the Voltage to 85% of the Player,
So my advice to you is:
1.Wire a cable(say 'A') 0.7mm thikness from the Battary(+ve).
2. Connect an othre wire (say 'B') 0.7 thikness to any metal part of the boady of the car.
3. connect the both wire 'A' and 'B' to the RADAR Detectors's (+ve) and (-ve) stockets respectively.
bye.
Username: Sony224422
Deep River, CT US
Post Number: 266
i had mine hooked up to my cd player and grounded with my cd player. it worked fine but it was a BBBBB to do. the wires inside are so small.
Need to Register?
Forgot Password?
Enable HTML code in message
