What cap? what gauge wire?
Username: Scott_t
Post Number: 62
i need a cap to go with my orion 1200D amp and my 2 type-r subs i was looking at https://www.sonicelectronix.com/item_5978.html
or
https://www.sonicelectronix.com/item_5979.html
what gauge wiring amp kit will i need?
i was looking at this
any help would be great.thx
https://www.sonicelectronix.com/item_1713.html
and i am geting all the higher gauge wire and bigger cap bacause i am planing to add another amp(orion 1200D) and 2 more subs(type-r) eventuly.
any help would be great. thanks
Username: Xkawn
Post Number: 236
you will need a high output alternator and a big one at that. a cap will only mask the problem of a lack of voltage in which a HO alt will actually fix it. if you do not get HO alt and choose to go with the cap you will end up ruining your electrical system. if you still want a cap, i seen someone on here say to cal the manufacture and ask what the esr capacitance rating is and it needs to be low. as far as the wiring, if it suits your needs then your fine with it. i mean as far as lengths and sizes and the physical componants. i myself and quite a few of the others on here shop at www.knukonceptz.com
