Stop the rattles
terpsfan
what are some alternatives to dynamat. i have a 93 accord that rattles so bad....help please...
Bassblaster
Tighten screws and bolts. Other than that Dynamt or foam is it I guess.
Username: Kennyman
I've used a few strips of cardboard behind my licence plate before, but using dynamat will improve the sound inside
