Infinity 12" Reference series 1232W
RyanInfinitySystem
It says the peak on these speakers is 1200W, and I have 300W running through each now with a crossfire 600W amp. I was thinking about upgrading to a 1200W amp. Is it ok to put 600W through each speaker, being reference series, or should I just stick to my guns. If I do upgrade what amp would you recommend?
RyanInfinitySystem
C'mon anybody?
fosgate
1200 will be good but your best bet would be a Rockford Fosgate Power T10001bd at 1000w rms.
