Not too pricey 15" sub atleast 500w RMS
Username: Koveaudio
Post Number: 34
i need subs that are atleast 500 watts RMS but not too expensive, preferrably 15".
Username: Koveaudio
Post Number: 35
what about kicker comp vrs? i'm not sure how i would run them though, i have a 100 watt class d mono amp, and they're DVC, how would i run them? and should i get dual 2 ohm or dual 4 ohm?
Username: Its_bacon12
Post Number: 438
it depends on what your amp's power output is at 2 and 1 ohms
what is the make/model of the amp?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 2008
try Adire Shivas, Brahmas, or Tempests.
they should fit the bill nicely.
www.adireaudio.com
lower priced for great subs, and even the Shivas are rated to take 650wRMS each for a 12"
should take what you have to put into them.
Username: Koveaudio
Post Number: 36
its a pioneer amp, its 2 ohnm stable and it'll run 1000 watts when it has a 2 ohm load.
Username: Glasswolf
Post Number: 2028
RMS or Peak/MAX?
Username: Koveaudio
Post Number: 37
RMS
Username: Glasswolf
Post Number: 2049
that'd be 500wRMS each for two subs, and the CompVRs are only rated for 300wRMS each.
at that power output look for subs rated for around 500-650wRMS each for a pair of them on that amp.
you'll want two 4 ohm SVC subs.
Post Number: 446
two 15" comp VR's would do the trick, 500w rms each go with dual 2 ohm version or single 4 ohm (if available)
Username: Glasswolf
Post Number: 2055
oh yeah he did want fifteens didn't he
I was thinking twelves.
