HELP wats a good dual or 2 singles subs for a SUV that is under 300 bucks
Username: Redsoxrich88
im lookin for 2 single subs or 1 set of dual subs that costs under 300 bucks. i want them to be loud but still have good quality. whats the best?
Username: Jakeyplaysbass
Post Number: 128
what do u mean by 2 single subs or 1 set of dual subs...im just a tad confused.
is that 300 for everything or just subs
like a dual set of subs like there are 2 subs inside a box thing. or just two regualr subs. that toatl cost should be around 200 hundred sorry
Username: Thejackal
Kansas
Post Number: 9
So does that price need to include an amp?
Username: Rovin
Trinidad & T...
Post Number: 1849
For $220 2 Alpine 12" type R 4ohms dvc - EBAY
na thats just the price of the subs
Username: Dustin3
Tigard, Or U.S.
Post Number: 60
what do you mean regular subs?
Post Number: 129
you probably should just save up some more money...200 is not much at all for everything and you most likely wont be happy with what you get for the price.
then wats a reasonable price from sum good 12" subs and wat are the subs
Post Number: 130
you can get a solid pair of 12" subs for around 200...but amp box wire and such will put you at 400-500
no,
2 comp vrs = 115$ altogether on ebay
audiobahn A8002t amp = 180 on www.onlinecarstereo.com
altogether = around 295$
the amp will power both comp vr's also...
Username: Rovin
Trinidad & T...
Post Number: 1859
thats an ok deal - why are u hiding behind an Anonymous post ? .
U did not say anything to be embarassed about ....Upload
Post Number: 131
you still need a box and wires...so ur still looking at 400ish
Username: Dustin3
Tigard, Or U.S.
Post Number: 64
or you could get 2 kicker comp vrs in the already made for kicker box (ported) for around 260 on ebay
