How do you measure the length of a slot port
Username: Gr8ride
sorry for this newbie question. the port is going to be shaped like an L, now would the length be both slot walls added together, or just the wall that is running along the back of the box? i already know the box dimensions and port height, width, and length. any help would be appreciated. sorry if this is confusing, i don't really know any terminology.
I don't know much on it but there are sections on www.the12volt.com & www.bcae1.com that tells you what to do
Username: Need4bass
We-Be-Swamps, Louisiana
Post Number: 134
Use the total length of the port (whatever shape it is) as the "lenght measurement".
Username: Gr8ride
they have some good calculators and good information, but maybe i'm missing something. they just give me the port length, not really where to measure it from or how.
Username: Gr8ride
i appreciate that fellas
Username: Six
Flint, MI U.S.A.
Post Number: 114
Measure the long side of one piece and the short side of the other. That way if you were to flip the bottom side of the L around they'd fit together correctly. (It doesn't matter how they cut and fit together either.)
Hope this helps.
Username: Gr8ride
i sure do appreciate that....
Username: Six
Flint, MI U.S.A.
Post Number: 116
lol. thought it'd help.
