Infinity Perfect Crossover Issue (help please)
Username: Kyle_allen
Post Number: 32
My tweeter started shorting out in my passenger door. It only does it at high levels but then won't come back on until a few days later. I'm running 100w rms, so they are over powered or clipping. I have the gains adjusted correctly. I notice the coil on my crossover has formed what looks like bubbles inside the plastic covering. what caused this. Is it fixable? If not what crossovers should I purchase to replace my perfects with. Thanks.
Post Number: 33
bump
Post Number: 34
Anyone?
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 863
I had this happen to my old Perfect set as well. I never found out the acutal problem, but I think it was just a defective piece. Where'd you buy the set from? If it has a warranty, give Infinity a call.
