JL 6w0 worth it
Username: Bakerj72
Regina, Saskatchewan Canada
Post Number: 64
i'm either going to go with the coax tr's 6" or go with the 6w0 and make a mounting bracket... i have a truck and i dont plan on getting anysubs but i like bass will the 6w0 give me a significant bass difference versus the coax tr 6" and what about sq
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 456
the 6W0 will give you a lot more bass compared to the 6.5 coaxial speaker. i've seen that sub before, its pretty big, if you plan on putting it in your door you'll have to do a lot of modification. almost 4 inch mounting depth
