Port: Flaring PVC pipe?
Username: Andrew571
Post Number: 22
1:I really dont want to hear the port noise from cylindrical PVC pipe - is it really that bad?
2:Anyone know any easy ways to flare 3 inch PVC pipe in anyway...i read a tutorial on it and its so confusing i almost wanna buy this flared tube from crutchfield. http://www.crutchfield.com/cgi-bin/ProdView.asp?g=745&I=495PNR3
Any feedback about port noise reduction would be ownage. Thanks.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 718
a flared port end wont solve port noise.. it will slightly lower the tune of the box.. if your port has enough area there will be no port noise.. if its to small it will
Username: Rovin
Trinidad & T...
Post Number: 1616
Fusion Audio also make those Aeroports & costs about 1/2 of that brand .........
