COMP VR's or Type R's
Username: Thugginpali96
Post Number: 11
Which are better? 2 12 inch Comp VR's or 2 Alpine Type R's Dual 2 or 4 ohm?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 533
type-R
Username: Homegrowncam
Watauga, TX United States
Post Number: 110
Type R's easily.
Username: Cenus
Hicksville, Ohio Usa
Post Number: 554
well imo its a toss up, the cvr will have better spl, but a lot of ppl consider the type r to have better sq but i would say its pretty even. both are good subs and they should satasify your needs unlees your used to hearing a xxx, or avalanch everyday.
Post Number: 16
Ok well what the hell is spl and sq??? I'm new to this sh!t lol. And what's better, ported, bandpass, or sealed box??
Post Number: 541
SPL= Sound Pressure Level (How Loud)
SQ= Sound Quality (How good it sounds
Never do bandpass, SPL=Ported, SQ=Sealed
Username: Jakeyplaysbass
Post Number: 108
you will probably want to do ported for both the type Rs and the compvrs, depending on what you get.
I like the type R 12s alot, they sound pretty clean and hit hard with the correct box and amp.
ive also heard cars with comp vrs that sound good but ive also heard them that sound horrible.
Post Number: 18
Damn i have sealed box and man do these subs hit and the quality is great. i dont wanna lose the quality. i'm talking about the type r's. i mean is it a big big difference on how loud they with the ported box and a big diffference on the SQ with the ported box? I have these subs wired to half an ohm so they're hitting. also anyone know why these subs are 1500 watts max, but a 500 watt rms??
