Need components and amp
Username: Lanzarchamp
Bakersfield, California United States
Post Number: 119
anyone know of some good components i could get with a good 2 channel amp for around 400
Username: Yada
Post Number: 29
Kicker KX350.4 Just got one for $150 ish from locusaudio shipping included, Alpine has decent mid $200 range Amps. I really like the kicker, Bridge it up 2 channels and you should get enough power to run most things. Assuming you will only run 2 fronts. If not you can run it at 4 channels just as well.
For speakers $250 can get you quite a bit of choices. I like infinity Kappas. Many here would recommend ya rainbows etc...
Hit up a circuit city or bestbuy and test them all out see what you like.
Username: Robert_d
MIA, FL USA
Post Number: 237
the xenons are pretty nice too
they come with the same rms 1-4 ohm
like the xenon 100.2 is 150$ shipped and is 100 rmsx2 channel 1-4 ohms
