Drilling box down to trunk?
Username: Pitbu11
Nm
when drilling a box down to the trunk is it best to drill them from inside of the box or to use those L looking braces to drill from outside and what type of screws are best? like length and width wise been having problems with box moving around in trunk.
Username: Pricey1985
Sydney, NSW Australia
Post Number: 21
hey, i used just some bolts going through the inside of the box, although the L brackets would be easier, i put them inside because it looked neater and a bit more secure in the case of someone braking in and knoking them off.
Username: Scubasteve
College Park, MD
Post Number: 665
please, please make sure you don't drill into the gas tank, and I use L or S brackets usually
