Apache model 600
i need to find out the wire diagram so i can install this alarm if anyone can help please email me back at wpolski2001@yahoo.com
I installed my Apache alarm this weekend and for some reason, the siren goes off in an extremely low sound when I close my doors (even when the alarm is disarmed) and only stops when I disconnect the siren. The alarm and siren work well when it's armed, but when it's turned off, I need to correct the problem of it my siren outputting a low tone when it shouldn't be going off at all. Please help. Thanks.
blkapache
Nevermind. I discovered that the negative wire was loose so I corrected the problem. Thanks.
