Instead of a distribution block...
Username: Hellyhans
Post Number: 11
Ok, here's my dilema
1: My amp has 8ga wire to it.
I'am running 4 ga from the battery.
Instead of a DB, can I buy a capacitor and wire the 4ga to it and then have my 8ga + wire connected to the cap??
2: if not.. I will need to ground my amp.. since its a 8ga wire.
If I do get a DB block with 4ga in and 8ga out... will I need to get a DB for my ground also,4ga to 8ga?
My 8ga wire will be no longer than 2 feet.
3: And If I get both a cap and DB... where should the cap be? between the DB and AMP or before the DB?
thanks
Username: Comp98
Philadelphia, PA USA
Post Number: 115
here's a simply fix for your problem:
http://www.cardomain.com/item/LITRA48
I don't know if its your best option but it's the cheapest one you might want to consider.
