Infinity 310a wiring question.. H E L P
Username: Stevehume
Post Number: 12
hi all... i just bought this amp last night and im hooking it up to 2 10"Infinity SVC... my question is the amp has 2 sets of + - and it says to hook one sub up to each one... can I not just go from the positive left to the negative right? ??? any ideas ???
Username: Stevehume
Post Number: 13
its a mono block class D 1 channel amp
Username: Stevehume
Post Number: 14
anyone??? i want to get this in tonight.. ill let you know how its sounds.. its supposed to be a cheater amp...
Username: Basshead86
Ocala, FL USA
Post Number: 2356
hook the positive wire on the first sub to the first + and the first negative wire on the first sub to the first -.
and then do the same with the second sub.
Username: Stevehume
Post Number: 15
hmmm i have one box with one set of black and reds .... i was going to hook up the subs in series... do i need a new connection to allow for 2 sets of reds and blacks? so i cannot hookup in series?
Steve
Username: Infinity_addict
Santa Rosa, California USA
Post Number: 181
are these newer or older models? give us some specs to work with. RMS wattage of each sub, their impedences, and amps output at various loads.
