Alternator!
Username: Iufan4lifeul
Post Number: 537
Ok, who sells really good HO alternators? I need one for a Mitsubishi Lancer. I really don't want to spend over $200 or upgrade the big 3 wires etc. Can I just get by with like a 175 or 150 amp alternator for that much and not upgrade those wires? Thanks!
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1279
your big-3 would be the FIRST thing you should upgrade.
those wires are how your alternators power actually gets to the batt/amp/everything!
check out:
4alterstart.com
excessiveamperage.com
Post Number: 538
I have a BUNCH of left over 8 gauge wire from my old amp kit. Can I run dual 8 gauge everywhere?
Post Number: 539
bump
