BOX BOX BOX!!!!!!
Username: Pikesh
Toronto, ONtario Canada
Post Number: 224
whats a good boz which would give LOUD BASS For dual 10" subs..
BAND PASS dual 10"
SEALED dual 10"
PORTED dual 10"
i ve used bandpass and it was LOUD!!! But whats better cuz i am thinkin of changing.. stick to bandpass of I want a bo that would give LOUD Bass to sum it up.. From which box i would get the louded bass out of those 3.. than k you for ur time.. really appretiated
Username: Pikesh
Post Number: 225
plz guys
Christofer
Sealed will give you a tight solid bass wont be as loud as bandpass tho. If ur looking for "loud" then go with bandpass, its the best to give most output but the sound quality if not the best..
Correect me if i am wrong
Username: Pikesh
Post Number: 226
ok thnx chris ne one else????
Username: Pikesh
Post Number: 228
Username: Rovin
Trinidad & T...
Post Number: 1251
Ported for the best balance of SQ & SQL - bandpass boxes are totally out ,more for beginners or ppl who just like banging loud without a care of SQ ...
Sealed may not satify u cause u said u want loud ...
Username: Pikesh
Post Number: 229
SQ n SQL!!!???? is that like tone? or something.. i mean i want LOUD BANg!!! but not outt tune.. is that wha tu mean.. kinda like that rough dry sound?
Username: Rovin
Trinidad & T...
Post Number: 1254
SQ = sound quality
SQL = sound quality loud
SPL = sound pressure level , meaning just annoying loud with no care of how good it sounds
Username: Pikesh
Post Number: 230
ohh thnx man...well i have bandpass right now lol its LOUD AS HELL.. well i am thinking about buying this box.. .so you think the subs will be LOUD in that box?
in terms of Loudness... thnx rovin
http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10042295&catid=1 1062&logon=&langid=EN
Username: Ctx
Post Number: 162
no.... 6th order series tuned isobaric bandpass
Username: Rovin
Trinidad & T...
Post Number: 1257
post a link to your subs 1st then i can give an opinion based on specs shown ....
BTW - that site has it really expensive cause pre-fab boxes like that can be had $30-$50 online .....
Username: Pikesh
Post Number: 233
lol rovin i work at futureshop so i get staff discounts but ur right... they are expensive i know they make alot of money frmo them..
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000F S10040094&catid=11051
here are the subs...
