Attn: Owners of the RE RE
Username: Iufan4lifeul
Post Number: 526
Has anyone else had the foam part that is glued on to the steel surrounding the subwoofer start coming off? For some odd reason mine is coming off all of the way around letting a bunch of air leak. I think I am sending it back to get a brand new pair of RE subs. Here is a picture that might help illustrate it better. It isn't the actual surround, but the foam stuff by where you screw the sub into the box at.
Username: Ishkabobble55
Post Number: 103
how is the foam surround coming off letting it leak air? the speakers rubber surround is glued to the basket and the foam doesnt hold the rubber surround on?? did you take out aa screw and accidentaly let it catch the rubber surround and tear the glue? i have two 8"s with no problems yet, and i push dem things!
