Like
What would you go with?
CaseyK
http://www.crutchfield.com/S-1yvNbewrEId/cgi-bin/ProdView.asp?g=520&I=2065C124
http://www.crutchfield.com/S-1yvNbewrEId/cgi-bin/ProdView.asp?g=520&I=236T4512
http://www.crutchfield.com/S-1yvNbewrEId/cgi-bin/ProdView.asp?g=520&I=037AW1051S
Username: Eprussian07
Post Number: 11
I personally like the MTX thunder...
You can also check our the Resonant Engineering .RE line, their 12" sub goes for $69 before shipping, and is a pretty good sub. Check them out at www.reaudio.com
What kind of amp do you have?
Username: Tdbdadrummer
Post Number: 418
Pavel is right, the RE would be better than all of those.
But if I had to choose from those, the Kickers would win out.
Post Number: 419
Also, how much would 2 12" 4 ohm SVC RE SE's be? If I can get 2 for under $300 I might go for it...instead of the VMAX's.
Username: Thigpen
RVA, Va Usa
Post Number: 133
I'm pretty sure it says on the website all SE's are dual 4 ohm and they run about 169$ for a 12" and 149 for a 10" before shipping, i believe
Username: Taylor17
Kopperl, Texas
Post Number: 3080
Don't know about that, but the website were I just checked the price list showed them at $185 for a 12.
Username: Thigpen
RVA, Va Usa
Post Number: 134
I could be wrong, but from the posts about RE prices id seen before they were straight from RE, and seing as RE doesnt have the prices on their website, it wasnt them. they have a few dealers that ive been, and most of them had a lot higher jacked up prices so that could be why their more. but from earliers posts if you call re i believe they were 169 but they coulda raised the prices since i read the posts
Username: Taylor17
Kopperl, Texas
Post Number: 3081
This was off another forum...
The thread is about 8 months old... prices could of changed by then.
Prices direct from RE... butthe 169 sounds right now that I think about it.
I need to get an updated price list!
Post Number: 421
OUCH...$169 before shipping is a little out of my price range...guess it's still gonna be the VMAX's.
Username: Robert_d
MIA, FL USA
Post Number: 185
i stil cant decide if i want 2 15" se or 1 15" sx
i wish it was april already then i would get the 18" sx for sure
Username: Rovin
Trinidad & T...
Post Number: 1219
Tyler - why would u want a 300wrms vmax when Alpine type R 500wrms sells for $117 online + s/h ???
Even Diamond D3 is a better sub .
Some how i find that cv vmax is kinda tame looking . lol
Username: Thigpen
RVA, Va Usa
Post Number: 136
i mean i dont know about VMAX's because im not a car audio pro but if you want something thats only 50 bucks more, id save up for the 50 bucks which will take a few days and then end up with something better instead of spending 50 less and being stuck with someone of worse quality, that is assuming the SEs are better since everyone around here hypes them up a good bit
Facebook
Shop Related Deals
Directory
