I need components.
Username: Jakeyplaysbass
Post Number: 65
I need a solid pair of component speakers from around 200 bucks. I want something that has very high sound quality and also good midbass. I have 2 12" alpine type X subs so i want to keep the SQ as high as possible...i do not have an amp so any sugestions on a 2 channel amp would be great also. thanks
Username: Mixmastaspig
Oknagan, B.C Canada
Post Number: 105
dark blue 2 channel
http://www.audissy.com/db_amps.html
runs around $400 I am getting the 4 channel bridges to run my component speakers as well as the 1000.2 class D amp!
Okanagan, B.C Canada
Post Number: 110
some speakers:
http://www.audissy.com/helix_speakers.html
Not EXACLTY sure of prices but ther offer extremly high sound quality!
Username: Tdisanto
Post Number: 246
CDTs are pretty solid speakers.
Eclipse amps will do your speakers justice and shouldnt break your wallet too bad, check ebay.
Post Number: 66
thanks, if i bumped it up to 300-350 for a set would i get alot better SQ? or would they just get louder? i have the money its just im 17 and want to spend as little as possible.
Username: Kd7nfr
Montpelier, ID United States
Post Number: 995
For around $300, you can get a pretty solid set of components. I'm still deciding on my new set... I've blown quit a few in my day.
Username: Tdisanto
Post Number: 269
yah that price range will put you in a better category of speakers.
What are you going to do as far as install.
Post Number: 67
ill get a custom install at a local shop (its good) and ill get a good price on it because ive gone there for awhile.
Username: Thigpen
RVA, Va Usa
Post Number: 126
im 17 with money too looking to spend as little as possible also.. can someone give me like 2 or 3 brands AND models of speakers in the 250-300$ range.. i just want some speakers that will be on par with the 2 RE SES i get
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 858
For around $200, I have been blown away by the Polk MoMo MMC6500 separates. They sound better to me than the Infinity Perfects I had about 6 months ago.
Username: Kd7nfr
Post Number: 1007
Alpine Type-R's and Type-X's are still high on the list for me. I just have WAY too much bass for 'em anymore, and need some seriouse components to keep up...
Post Number: 120
Jake are you still looking for CRAZY high end front speakers?
Try out some Brax, or Helix, they are awesome (comes at a price though)
Post Number: 68
does rainbow have a good set of components for 300ish?
Username: Tdisanto
Post Number: 344
Well all of rainbows components are good. I dont know what they offer for $300, youll have to contact a dealer.
Elevation Audio Concerts
http://www.elevationaudio.com/concert650.htm
