Infinity 10VQ or Alpine Type-R?
Username: Afripino
Well...I'm looking to upgrade my JL 10W0, and I'm running a RF 500s (500wRMS @ 4 ohms). I'm looking to have a moderately sized sealed enclosure ('97 Dodge Neon trunk) and would like to know which would be the better sub SQ & SPL-wise. Thanks!
Username: Rovin
Trinidad & T...
Post Number: 1172
What model Rf is that & how many & what size of subs u are thinking about ?
Username: Rovin
Trinidad & T...
Post Number: 1173
i know your headline looks like u want a single 10" but i still had to ask to be sure - lol
Username: Afripino
oh yeah...it is a single 10. the RF's model is a 500s (2002 model).
Username: Dankum
Post Number: 76
infinity, def.
Username: Rovin
Trinidad & T...
Post Number: 1175
IMO - Somehow i like & trust the Alpine more ....
Username: Afripino
Alpine Type-R (2x2ohm DVC SWR-1022D):
Power Handling Capacity (RMS) : 500W
Power Handling Capacity (Peak) : 1500W
Frequency Response: 26Hz -- 500Hz
Sensitivity: 85dB
xmax: 13.35mm
Infinity 10VQ (1x4ohm SVC 10VQ):
Power Handling, RMS: 400W
Power Handling, Peak: 1600W
Frequency Response: 25Hz - 400Hz
Sensitivity: 87dB
xmax: 16.75mm
Just from specs alone I'm leaning towards the 10VQ. I have found both companies to have quality products (I have dealt with them both in the past) and I think I'd be happy with either, just looking for the better of the two. Hmm....
Username: Afripino
Well...looks like I'm getting the 10VQ. Hopefully this whole "variable Q" thing will prove to be worth it.
