$200
Schyea
Whats the best HU in this price range? I know its not much, but thats all I have to work with at the moment.
Username: Marines
Post Number: 43
Check bestbuy for good alpines and pioneerse for under $200 they are all about the same price like around 154-179 heres a link note on page one is alpine for 179 and the second page the pioneer for 179 do some comparrison on what you think would be the better deal as in features and stuff
http://www.bestbuy.com/site/olspage.jsp?id=pcmcat52600050007&type=category&paren tCatID=false&initialize=false&initialize=true&_requestid=68779
Username: Brandonk17
Post Number: 28
I would also encourage that you look into alpine... they make good quality HUs in your price range... check Ebay... you might be able to get a better model for less if you catch the right auction... also look at eclipse to see if you can find one on ebay
Username: Tdisanto
Post Number: 234
only go to best buy to listen to the HU your looking at buying, dont buy it there. Ebay is going to be your source for new HUs for a very reasonable price.
Alpine and Premiers are going to be your best bet. Eclipse tends to be more expensive.
Schyea
Thanks for all the help guys, Ill be looking into some Alpines and Pioneers then.
Username: Marines
Post Number: 51
n/p man just trying to help out cuz i was in ur shoes once not knowing what the heck was what and getting overwhelmed and stuff, been there all of us have
Username: Xkawn
Post Number: 178
pioneer premier from ebay. too many problems with the alpines.Pioneer DEH-P770MP is right about $200 with it's shipping on ebay. i have the deh-p8mp. great decks.........
Schyea
Alright Ive looked into that DEH-P770MP and looks great, and its in my price range. Probably going to buy it unless someone has something else to say?
ricky g
id also look at the Clarion ProAudio DXZ555MP
Schyea
What about the Kenwood KDC-X689?
Schyea
Or even the KDC-X789?
Username: Xkawn
Post Number: 181
in kenwood your just buying a name. they're products are not as good as alpine, pioneer, eclipse and a few others. the reason i suggested pioneer over alpine (who'm both build good quality products in your $200 budget range) is because alpine had a defect in they're models early this year. yes, being a really good company they re-called them and took care of the problem asap, but buying on ebay i personally wouldn't want to take the chance that you get one of the re-called models and have to pay shipping to and from again to get it resolved. it's just a risk factor. pioneers haven't had any reliability issues that i know of. i have the deh-m8pm. outstanding decks in the premier line.
Username: Marines
Post Number: 59
i know that the pioneers after about a year or two the buttons start to freeze
