Whats the difference?
Username: Sbrizzi
Boone, Nc
how much better is a kickerL7 than an L5
is there a big difference between a 15inchL5 and a 12inch L7
the 15 well get a little deeper but the l7 would brobably get louder
Username: Ucfsaxman
Oviedo/orlando, Fl
Post Number: 172
they should be similar in loudness the L5 will have even worse sound quality it depends on the enclosure and the power you give them.
Username: Taylor17
Kopperl, Texas
Post Number: 3038
There isn't much of a difference from L5/L7.
Just power handling.
