Db
i have 2 alpine type-r in a ported box in a blazer
wirg a jl 500/1 amp
any idea about how many decibles. i have a good prefab box
Username: Dementedvisions
Cedartown, GA
Post Number: 13
maybe 80 DB
man what can i do to get the full power from these things and then about how many decibles
and they call this an sql sub and it dont even get loud
Username: Jakeyplaysbass
Post Number: 61
probably high 130s maybe 140. very hard to tell
Username: Jonesp
Post Number: 54
i think they are loud enough i also have 2 running a mrd605 amp. it bangs i mean you can hear it down the street and it sets off car alarms but anyway im gonna add 2 more and push them with 2 1200.1 kicker amps. and custom box i believe i wil be hitting in the 120-130 then mainly because that 8 times as much power im going from 300rms to 2 sub to 600 rms to four subs
Cedartown, GA
Post Number: 14
130's there is no way in a prefab man c'mon
well first you need to build a box get rid of that prefab thing. those subs would sound great with a seald box.
Username: Jonesp
Post Number: 55
jake there is no way he is hitting 140
he has half the rms power crappy box and a waste of a slash amp
Post Number: 62
lol i would like to see that set up if you are setting off alarms with 2 Rs getting 300 rms each...
Username: Mixmastaspig
Oknagan, B.C Canada
Post Number: 93
I hit 139.6 DB with 2 type R's ported store box sub with a sony amp
i dont really know i like ported boxes would it be that much better in a seald box??
and jones p how much are you spending
Post Number: 63
ah i did not read about the prefab..thats my bad but hes still 130ish i would guess.
Username: Jonesp
Post Number: 56
im serious maan no joke i swear on my life i do
but im goin to end up spending $1000 more
custom box
2 new amps
wires
battery
2 more subs
car dynomated
Username: Jonesp
Post Number: 58
if were both hitting 130 ish right know what will i be hitting when im done
jonesp why spen all that for some type-r
why not jl's
Username: Jonesp
Post Number: 59
oh because im also doing show subs and i will get more bang for the buck this way. when im finish i would spend a total of 1500
think about it
4 12's (type-r 05')
2 amps (kx1200.1)
wiring ( four gauge)
custom fiberglass box ( me and a buddy)
neons cartoys
battery ( one with the yellow top)
thats pretty cheap for all of that
sounds nice
i already paid half of that :-(
550 for amp
250 for subs
Username: Jonesp
Post Number: 60
why did u get a top of the line amp for those subes
dont rub it in i went to car toys...
thats what they said i should get
Username: Jonesp
Post Number: 61
im surprised they weren't like BUY THIS 9500 it hits so hard. buy this W7 it sounds so good . and get the most expensive amp.. let us buil you a box and in stall with 0 gauge wire. and you will need a new battery, alt and 2caps. and dont forget the dynomatand the eclipse HU. and just in case some one tries to break in get this $400 dollar car alarm.
idiots then you ring it up and its like 5-7 grand
should i trade my type-rs for a type x
Username: Jonesp
Post Number: 65
no, atleast i wouldn't not for one.
type-r are way louder and i like spl more than sq
Username: Invain
Michigan United States
Post Number: 3830
The amount of decibels you hit depend on:
1. The subwoofer it's self, and the amount of air it moves (cone area x average xmax)
2. Your amp, amount of wattage running to your sub.
3. Your enclosure plays a huge role, it's impossible to say what your hitting without knowing what kind of box.
4. Your vehicle, cabin gain also plays a big part in it, and the same setup may sound different in a different vehicle.
5. Your vehicle's charging system can actually play a part in it as well, determining the voltage going to your amp, which in turn determines the wattage produced (if you have an amp with an unregulated power supply)
To sum it up, it's simply impossible to determine how many db's a person will hit, even if all the factors are known. There's just too much stuff that can effect the outcome, and nobody can honestly give you a close number. The ONLY way to determine what your hitting, is to actaully get your system metered.
Username: Sexy_kuta
Post Number: 64
how about mine!!
one 15 inch onxy monster sub, 5000 rms haha
one jbl 1200.1 mono block amp
got the amp at 1 ohms,( well i will soon due to some problems!)
and the box is tuned to 35 hz and [ported
holla!
Okanagan, B.C Canada
Post Number: 118
I have 2 Type R 12" subs running of an XPLOD AMP, in a bassworx FUTURESHOP ported box and I hit
139.6 DB in street class B
came in 5th place
Post Number: 119
I had no idea I allready replied to this post....opps
