Solder
Username: Baseballsc
Post Number: 36
Is there a particular kind of solder that works best for soldering speaker wire to the terminals in the box?
Username: Invain
Michigan United States
Post Number: 3846
Just make sure it's rosin core.
Username: Zacdavis
Beloit, Wi
Post Number: 270
The key to soldering them is tinning both the wire lead and the terminal cup first.
Also, it's a trick getting the terminal to tin without melting the plastic that holds it, lol.
Anywho, any typical electronics solder will work.
(a Sn60/Pb40 core solder with 3 to 4% Flux)
aka 60/40 with flux
