Sub BOx Visonik
Username: Caraudio
Toronto, Ontario Canada
Post Number: 182
Any reccomendations? 12" 1250RMS
Username: Rovin
Trinidad & T...
Post Number: 1192
ALOT !
kicker 1200.1
JBL 1200.1
Orion 1200
RE 1200
Ed 9
Phoenix Gold Xenon X1200.1
Lots more but u need to post what VC config & sub model ...
Where u the same guy who posted about this wk before last ?
Username: Caraudio
Post Number: 190
Umm i dont recall but here it is. I had the link just lost it its a 12" 1250RMS watts 2500Max.
Need am amp that will push 1000RMS say 1200RMS at max to be able to push my lanzars and visnoik either one i want. Ones 4ohm ones 2ohm and i also need the amp to be 1ohm stable if its not 500RMS at 4ohm.
Username: Caraudio
Post Number: 192
Wait i messured it and its 15" Visonik now ill brb as i find specs for this.
Username: Caraudio
Post Number: 194
Found em
15"
1500W Rms
3000W Max
180oz Double Stacked Magnet
Sensitivity: 87.4 dB @ 1w/1m
Mounting Depth: 7"
Vented Box: 5.75 Cu. Ft.
Port Size: 4- 4" D x 19.5" L
Sealed Box: 2.0 -- 3.0 Cu. Ft.
Username: Caraudio
Post Number: 195
http://www.rhinotronics.com/index.cfm/act/Catalog.cfm/catalogid/885/Featured/nul l/browse/wholesale/MenuGroup/Home/desc/Visonik%20V815D2%2015%22%203000%20Watts%2 0Dual%202%20Ohm%20Compition%20Subwoofer%20Speaker.htm
Thats the one.
Username: Rovin
Trinidad & T...
Post Number: 1194
So IT IS A 2ohms DVC - right
then this
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14805
Username: Caraudio
Post Number: 200
Lets use other thread okay.
Username: Tdbdadrummer
Post Number: 407
Is Visonik any good? That particular sub looks like Volfenhags competition series lol.
Username: Rovin
Trinidad & T...
Post Number: 1198
That same amp i mentioned above will run both sets of subs good enough .
This same thread ran about 2wks ago & I guess he did not get the answer he needed then. GW called Vis subs no good - but hey if this guy got it free who can argue with that ! .
Username: Caraudio
Post Number: 204
Yepp so go with the Hifonics 2005D?
Okay but say i hook up 2 speakers to the 650RMSx1 wouldnt that divide the RMS IN HALF:S??
