What's the difference???
Username: Tarek
Post Number: 9
What is the difference between the JL 12W3 V2.. d2, d4, and d6. Which is the best for rap?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 979
so im guessing you mean whats the difference between dual 2 ohm 4 ohm and 6 ohm?
well for one i was not familiar with the fact that they produced a dual 6 ohm. but either configuration will sound the same for rap. they just have different wiring options... for example
d2- you can wire to 1 ohm load or 4 ohm load
d4- you can wire to 2 ohm load or 8 ohm load
D6- you can wire to 3 ohm load or 12 ohm load
so you just want to match the sub with your amp for example.
if your amp is 1 ohm stable you want the d2
if you amp is stable at 2 ohms you want the d4
if your amp is 4 ohm stable then you want the d2
and if you have a JL slash amp you can use either d2, d4, or d6
hope that helps... main thing is that they all sound the same.
Username: Tarek
Post Number: 10
Yeah thanks I am getting the 500/1 amp.
Username: Taylor17
Kopperl, Texas
Post Number: 2977
So you're going with 2 subs?
That will change the ohm loads.
You can stil go with any of them except the D6's.
Username: Tarek
Post Number: 11
Ya I'm getting 2 JL 12W3's and was wondering what one to get (d2,d4,d6). And the JL 500/1.
Post Number: 985
he can still run the D6... that would give himn a 1.5 ohm load which a JL amp does fine. but i would just get the D2 and wire them series/parallel to get a 2ohm load.
Username: Taylor17
Kopperl, Texas
Post Number: 2991
Yeah, don't know what I was thinking. lol
They'll all work...
Username: Glasswolf
Wisteria, Lane USA
Post Number: 10636
the d6 is used mainly for 3 subwoofer systems. you can get a 2 ohm load that way.
there's no difference in performance between the various coil configurations really. It's just a matter of matching the right subs to the amplifiers you'll be using to drive them.
Username: Basshead86
Ocala, FL USA
Post Number: 1864
haha, here's my answer in the same, but different thread.
damn double posts.
https://www.ecoustics.com/cgi-bin/bbs/show.pl?tpc=4&post=468531#POST468531
Username: Alias747
MN
Post Number: 743
Glass, wouldn't you get a 4-ohm load, with 3 DVC 6-ohm subs? lol :-)
That'll sound very nice. JEEZ (2) 12w3v2s... Isaac, what town you from?
Username: Alias747
MN
Post Number: 745
Me? I am from Houston, MN. That is in the way South East corner of the state. Why, where you from anon?
