BOSTON ACOUSTICS SUBS
Username: Xpop2027
Miami, FL United States
Post Number: 9
I have a few questions. I have a 2004 Mercedes Benz C320 Coupe and I
wanna know what would be the best sub(s) for me. I went to the local
car electronics store and the guy there, which did my friends MINI,
said that I should get Audiobahn Subs or Boston Acoustic Subs for my
car. I wanted Two 12s and he recommended the ALUM12N subs from
Audiobahn or the G212 subs from Boston Acoustics also he said that the
SL Series Boston Acoustic components would be good. I have Precision
Power Pro Art Amps, the Pro Art 25 and Pro Art 50. I wanted to know
what Subs I should get and why? How about One JL Audio 12 inch W7? I
already purchased a Kenwood DDX-7017 Head Unit on eBay so I am willing
to spend about $1000 on components, subs, and installation. Thanks.
Username: Homegrowncam
Watauga, TX United States
Post Number: 77
well the audibahn would definetely be my last choice from that list. I haven't heard the boston acoustics but from what I have read and the specs they look good. And well of course the 12w7 will have great sq as well as spl. Now I am not sure on your amps though if they will be able to power the w7 or the others.
Username: Xpop2027
Post Number: 11
Why would the Audiobahn be your last choice? Why have I heard that they are so bad in this forum? My friend has one 10" inch pro compression sub from them and it sounds good. Well the 12w7 is pretty expensive what about other subs from JL in my price range more or less
Username: Xpop2027
Post Number: 13
Also what components do you recommend?
Username: Xpop2027
Post Number: 15
