Box help.. anyone who knows
JustSomeGuy
If i build a box for a 12" sub that has external dimensions of 16"High, 17.5"Deep and 17"Wide with a 4"Port that is 14"Long, what will it be the volume and tune? will this box sound good, and how much more spl will there be than just a sealed box? Thanks for any help, you guys are awesome on this site.
Username: Rovin
Trinidad & T...
Post Number: 982
calculate it ya self with this ite www.the12volt.com
JustSomeGuy
i calculated it to be 2.08 cubic feet and tuned to 31 hz. will this sound good and how much more spl will there be compared to a sealed box, or can you tell?
Username: Kd7nfr
Montpelier, ID United States
Post Number: 952
Depends on your sub.
