Nooby has a ????
rosco8118
Hi I have a kicker kx600 and it does 600W @ 2 ohm and 300W @ 4 ohm and i was wondering if it will work for this Type R, this is the sub i was going to buy, http://www.sonicelectronix.com/item_4194.html
will i be able to wire it so it will get 600 watts or not?
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 1163
yes...that amp/sub combo is a good match.
